quazi_dude
Jun 16, 2012Aspirant
HDD Replacement - Expected Rebuild Time
Hi, I have a Netgear Utlra 6 with 5x2TB drives and 1x3TB drive. I removed one of my 2TB drives and then replaced it with a brand new 3TB drive. The rebuild has started but has been going for 3 days...
mdgm-ntgr
Jun 16, 2012NETGEAR Employee Retired
There shouldn't be any expansion when you replace a 2TB drive with a 3TB drive. Using single-redundancy you need two higher capacity disks for vertical expansion. Using dual-redundancy you need four.
