AllWin
May 30, 2012Aspirant
HDD's won't spin down [SOLVED]
Hello good people, me noob here again. I have a feeling that HDD's on my ReadyNAS Duo V2 spinning all of the time. I have enabled option to spiw-down disks after 20 minutes of inactivity but apparentl...
ReadySECURE
Jun 01, 2012Apprentice
When support is denied for HDD incompatibility, it is generally because the drives are the cause of the failure. If you are using drives that aren't on the HCL and for example the chassis fails, support would still be provided. The only real worry is that diagnostic some times requires getting a drive that is supported.
