skim32
Nov 10, 2015Tutor
Help - Readynas Ultra 4 Plus - I think the Data is okay, but the Readynas is not functioning
So an HVAC tech came out and flip the circuit breakers without my knowledge. Now my Readynas Ultra 4 Plus is not functioning properly. At first I could see it on PC. i could navigate to it by IP a...
Nov 10, 2015Guru - Experienced User
Just to clarify - the web ui is accessible, but data in the shares is not. And now settings aren't sticking, and manual firmware updates fail?
This sounds like a full OS partition to me. Can you delete the logs from the web ui (backup and system)? Don't try to download them, that could make things worse.
Also - did you have Crashplan installed (I'm thinking not, but want to confirm).
skim32
Nov 10, 2015Tutor
That's exactly right. And as a matter of fact, I did have crashplan installed. however it stopped working a while ago after they updated something. I never got around to fixing it. Something about having to update Java JRE on the ReadyNas, but had dificulty trying to do that. I did make a backup of the settings. I would try your seggestions, but a mod PMed me (mdgm) and asked me to put it into Tech Support mode. I assume he is working on it so I don't want to interrupt anything he/she might be doing.
