himore
Sep 28, 2013Aspirant
Help! Cannot connect to ReadyNas DUO anymore
Hi, I've had zero problems with my ReadyNAS DUO for the last 4 years, but yesterday I made the error of accidentally cutting power to it BEFORE shutting it down gracefully! I have made this mis...
aks
Sep 28, 2013Virtuoso
Not sure why Raidar cannot see the Duo, but I generally don't use Raidar.
Can you connect from a browser using the ip address directly?
To connect your laptop directly you need to set a static IP address on your laptop, as the Duo boots with a fixed network setting if no DHCP is available. Did you setup like this.
