geoffosmith72
Sep 27, 2016Follower
Help....I can access configuration but not my files :-(
My windows 10 PC undertook an auto update and since then Ive been unable to access drives mapped on my readynas or files stored on it. I can access the Readynas config using Raidar tool. Ive c...
Sep 27, 2016Guru - Experienced User
Start by going into windows credential manager and enter a nas username/password for 192.168.0.198
Daisyguarddog
Oct 04, 2016Aspirant
I had the exact same problem at home today - I tried all the things you mentioned. I have a windows 10 PC.
I fixed it by going to Settings>Network & Internet>WiFi Advanced Options and turned "Make this PC Discoverable" to On.
I can now access my mapped drives.
I hope this helps.
- StephenBOct 05, 2016Guru - Experienced User
I'm glad it worked. Is your network type set to "private"? If so, it should have already been enabled.
