zwerdlds
Mar 29, 2012Follower
Help me get SortTV working!
Hi everyone! I own a SPARC-based ReadyNas Duo (revision 1?) running RAIDiator 4.1.8. I'm decent when it comes to CLI, but not the best when it comes to dependency hell. My Duo is the slow-but-sure ...
dedmeet
Nov 28, 2012Aspirant
New issue:
SortTV fails at times with:
/usr/bin/perl: relocation error: /usr/lib/perl5/auto/HTML/Parser/Parser.so: undefined symbol: Perl_Tstack_sp_ptr
Fixed with:
apt-get remove libhtml-parser-perl
Reading Package Lists... Done
Building Dependency Tree... Done
The following packages will be REMOVED:
libhtml-parser-perl libhtml-tree-perl libwww-perl
0 upgraded, 0 newly installed, 3 to remove and 77 not upgraded.
Need to get 0B of archives.
After unpacking 1847kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ...
dpkg: serious warning: files list file for package `squeezecenter-readynas' missing, assuming package has no files currently installed.
15506 files and directories currently installed.)
Removing libwww-perl ...
Removing libhtml-tree-perl ...
Removing libhtml-parser-perl ...
Then install the updated cpan version
cpan install Bundle::LWP
Fixed with:
