alokeprasad
Mar 17, 2012Mentor
Help me select between Netgear routers N600 and N900
I am looking to upgrade my cable router to support gigabit and 802.11 N wifi. I have a Sparc Duo and other Netgear switches like GS108. Anyone here have experience with N600 (WNDR3800) and/or N900...
Mar 17, 2012Guru - Experienced User
I use the N900 (WNDR4500), and have used the N750 (WNDR4000) but haven't used the N600. The main benefit of the N900 wifi is with devices that can use 3x3 connections (for example Centrino 6300AGN equipped laptops). If you are mostly running 802.11g (other than the tablet), you might as well go with a cheaper router.
I am not sure why you are ruling out the N750 though - it is close in price to the N600, and sometimes is a bit cheaper.
