alokeprasad
Mar 17, 2012Mentor
Help me select between Netgear routers N600 and N900
I am looking to upgrade my cable router to support gigabit and 802.11 N wifi. I have a Sparc Duo and other Netgear switches like GS108. Anyone here have experience with N600 (WNDR3800) and/or N900...
alokeprasad
Mar 17, 2012Mentor
This sentence from SmallNetBuilder.com summarizes their opinion:
If you don't need three-stream N, you can give the WNDR4500 a pass. If you're set on a high-end NETGEAR router, the WNDR3800 would be your choice for features and the WNDR4000 for performance.
