TheRookieGB
Nov 14, 2012Aspirant
Help Please - Unable to mount Disks when removed
Hi All Need some help please: We have a Netgear ReadyNas NV+2 v2 with 2 western digital RED 2TB drives (also tried this with 2 x WD Green 2TB drives). We have configured the unit as XRaid2 an...
Nov 15, 2012Guru - Experienced User
You should be able to delete the partitions in Windows, even though it doesn't recognize the format. It might be that the drives are locked (not sure if the v2 units do that though).
Can you see the SMART stats on another system (acronis drive monitor will show them on Windows, there are other tools of course).
