winger13
Apr 26, 2014Guide
HELP. RN Pro Pioneer Edition) Not turning on, but...
Last night, the NAS restarted itself (within 1 minute) after I shut it down for the night. This has happened before maybe just a handful of times. The solutions in the past as been to use turn switc...
fastfwd
Apr 26, 2014Virtuoso
Bad power supply. You can replace it for $40: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151089
And you'll also need a $7 ATX power-supply extension cable: http://www.newegg.com/Product/Product.aspx?Item=N82E16812200121
