winger13
Apr 26, 2014Guide
HELP. RN Pro Pioneer Edition) Not turning on, but...
Last night, the NAS restarted itself (within 1 minute) after I shut it down for the night. This has happened before maybe just a handful of times. The solutions in the past as been to use turn switc...
winger13
Apr 26, 2014Guide
Hi FastFwd. I have a couple of questions.
1. What specific symptom(s) I am experiencing makes you believe it is a power supply issue?
2. Wouldn't a power supply issue mean that power supplied to the unit would be erratic or not working at all? However, the power seems fine, well, at least when it is on.
3. Would this be covered by Netgear warranty? I powered the unit on right around Jan 1st, 2010.
Thanks much for the detailed parts listing, BTW. Very helpful of you.
