msimswil2015
Jun 18, 2021Tutor
Help! RN426 FW update stuck: could not mount boot flash
I have had this unit for a while. It has been fine. Noticed there was a firmware update. Existing FW was 6.10.4 Hotfix (I think). Update is to 6.10.5. Ran update through the admin UI. Reboote...
- Jun 18, 2021
The next thing to try is to power cycle it.
If the flash has actually failed, then you'll need a new NAS (hopefully not the case!). So you might also want to check your warranty status (warranty is 5 years for a new purchase from an authorized reseller).
Jun 18, 2021Guru - Experienced User
- msimswil2015Jun 18, 2021Tutor
It's been so reliable for so long, I had forgotten how to switch it off!
Booting... updating FW...
Booting... 46% [] [] [] []
Booting... 94% [] [] [] [] []
Ahhh. It's working again. Thank you for the encouragement StephenB
- StephenBJun 18, 2021Guru - Experienced User
Great.
There is a bug in 6.10.5 - some folks are experiencing a login loop when they try to access the admin web ui. So you should definitely double-check that you can log in to that.
FWIW, I'm not experiencing this problem, so it's not affecting everybody. But it has been quite painful for the folks who are.
Thanks again. The UI seems fine for me too.
I discovered from logs that the scheduled backups over USB have been failing for a while. Not sure why. Running the job manually worked fine. Dodged a bullet today!
