msimswil2015
Jun 18, 2021Tutor
Help! RN426 FW update stuck: could not mount boot flash
I have had this unit for a while. It has been fine. Noticed there was a firmware update. Existing FW was 6.10.4 Hotfix (I think). Update is to 6.10.5. Ran update through the admin UI. Reboote...
- Jun 18, 2021
The next thing to try is to power cycle it.
If the flash has actually failed, then you'll need a new NAS (hopefully not the case!). So you might also want to check your warranty status (warranty is 5 years for a new purchase from an authorized reseller).
Jun 18, 2021Guru - Experienced User
msimswil2015
Jun 18, 2021Tutor
It's been so reliable for so long, I had forgotten how to switch it off!
Booting... updating FW...
Booting... 46% [] [] [] []
Booting... 94% [] [] [] [] []
Ahhh. It's working again. Thank you for the encouragement StephenB
- StephenBJun 18, 2021Guru - Experienced User
Great.
There is a bug in 6.10.5 - some folks are experiencing a login loop when they try to access the admin web ui. So you should definitely double-check that you can log in to that.
FWIW, I'm not experiencing this problem, so it's not affecting everybody. But it has been quite painful for the folks who are.
- msimswil2015Jun 18, 2021Tutor
Thanks again. The UI seems fine for me too.
I discovered from logs that the scheduled backups over USB have been failing for a while. Not sure why. Running the job manually worked fine. Dodged a bullet today!
- bedlam1Jun 20, 2021Prodigy
There is a bug in 6.10.4 & 6.10.5 which affects rsync backups, I suggest you revert to 6.10.3, which worked for me
