dizzyj
Sep 06, 2014Aspirant
help with data recovery after HD swap
Hi, I recently had a hd fail on my readynas duo. I took the remaining good drive and put it into a usb enclosure to backup my most sensitive data. I then bought 2 brand new HD's for the duo and ...
Sep 06, 2014Guru - Experienced User
I think you'd need ssh to access the data through the USB port.
I'd try linux reader on the windows system instead of the ext file viewer (http://www.diskinternals.com/linux-reader/)
