paulvk
Jul 28, 2011Aspirant
Help with downloading from FTP
Hi, I have a question about downloading from FTP via my Readynas Duo. When I google, I only find how to setup the readynas to acces files over FTP. Just like it is possible to download torrents,...
JarnoG
Jul 29, 2011Guide
My guess would be that if you can access files over FTP with your readynas, that's not much different from downloading them.
Aside from that, you can make a backup from a remote ftp server using the options in Frontview. I guess that's the easiest way to do it if you know the files/folders you want to go to since you can browse the folders of the remote FTP server. Using SSH you can probably also directly use the build-in FTP client to browse the folders and download stuff, but i've got no idea how that works..
