paulvk
Jul 28, 2011Aspirant
Help with downloading from FTP
Hi, I have a question about downloading from FTP via my Readynas Duo. When I google, I only find how to setup the readynas to acces files over FTP. Just like it is possible to download torrents,...
paulvk
Jul 31, 2011Aspirant
I just found this topic:
I see that there is no direct solution, but I'll try the tips that are given there. Any other tips are welcome :)
uniquesil wrote: Hi,
I have just purchased my first readynas product and it was because of reading info on these forums so thank you for that.
I currently have a semi-dedicated server with a bittorrent client for downloading my media, I would like to be able to download the files directly from my server to the readynas. Currently I am downloading them through filezilla (on my macbook) and choosing the readynas as the drive but the speed of download is much slower then if I download direct to my mac hard drive.
I don't want to use utorrent on the readynas as the dedicted server is hosted elsewhere and the speeds are much faster than my home broadband.
Is there an add-on that would allow me to download files direct from my server to the readynas? if so, which add-on program would you recommend. I am not very technical so an easy to use interface would be greatly appreciated.
thanks for your help.
