paulvk
Jul 28, 2011Aspirant
Help with downloading from FTP
Hi, I have a question about downloading from FTP via my Readynas Duo. When I google, I only find how to setup the readynas to acces files over FTP. Just like it is possible to download torrents,...
knorrhane
Aug 03, 2011Aspirant
If you enable SSH on your ReadyNAS you can use the program ncftp which is already installed. I don't know how comfortable you are with using a terminal but it's fairly straightforward:
-Download and install the add-on enablerootssh from the add-ons page
-SSH to your ReadyNAS writing:
-Type
-Type
-Navigate to where the file you want to download is and type
-The file will download to the folder you were when you first started ncftp
Now, the downside is that the ReadyNAS doesn't support the bgget command which allows a ncftp daemon to download in the background so you'll need to stay connected with the terminal until it's finished. I haven't managed to get the bgget command to work properly but maybe somebody else has?
Have fun!
NB! I'm not sure whether enabling SSH on your ReadyNAS renders your warranty void or not but better presume that it does.
ssh root@readynas-ipin the application terminal on your mac (password is the same as when accessing frontview)
-Type
ncftpand the ftp client will start
-Type
open -u username -p password ip-to-ftp-server
get the-filename-of-the-file
Have fun!
