spikass
Mar 21, 2013Aspirant
Help with setup NV+ v2.
Hello all, I recently bought the ReadyNas RND4000 NV+ v2 (Marvell cpu) which I understand is ARM based. It does not have the latest version of Raidiator (I think its 5). I've been looking around your ...
Mar 21, 2013Guru - Experienced User
If you are running v4 firmware, then you did not purchase an NV+ v2.
spikass wrote: ...concerning the latest firmware I saw that version 5 of the RAIDIATOR has been out since November. So I was wondering if I should upgrade via file or not. I managed to get the latest upgrade from the current RAIDiator but i only got the latest v4 firmware and not v5.!
Check here, to be certain: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Switching to flexraid/jbod requires a factory reset procedure. That will wipe your data, and reset your config to factory default settings
