spikass
Mar 21, 2013Aspirant
Help with setup NV+ v2.
Hello all, I recently bought the ReadyNas RND4000 NV+ v2 (Marvell cpu) which I understand is ARM based. It does not have the latest version of Raidiator (I think its 5). I've been looking around your ...
spikass
According to the site you posted my version is the v1. Which means that someone tampered with my package because on the front it says v2... I guess its a good thing it works at least. If I update my firmware to version 5 will I have the JBOD option available? And if not will I be able to setup the rest of my hard drives (2x2TB) as RAID 0 separately without a hardware reset? I have already installed my 2x500GB in a RAID 0 so I will install the first 2TB create a new volume then the second and do the same...?
