spikass
Mar 21, 2013Aspirant
Help with setup NV+ v2.
Hello all, I recently bought the ReadyNas RND4000 NV+ v2 (Marvell cpu) which I understand is ARM based. It does not have the latest version of Raidiator (I think its 5). I've been looking around your ...
Apr 15, 2013Guru - Experienced User
You have 4 drives installed and are using XRAID, correct? If true, you cannot get any data off of a single hard drive, the RAID-5 format spreads the data across the disks.
How much data do you have on the device?
