BalROCK's avatar
BalROCK
Host feature for SMB and FTP not working properly? OS 6.6.0
And yet another problem/question.
On both of my NAS 204 the feature "Hosts" for shared folders appears to be not working at all (form SMB and FTP - did not check other protocols)
FOR SMB - when I set a IP address and click OK everything lookes normal, but when in main settings window I click Apply (Zastosuj in my language version, right button at the bottom), settings window skipes to Security tab (first one) and when I come back to Hosts tab, the hosts list is empty. Tried several times with many shared folders - OS version issue ?
FOR FTP - I can normally set hosts, everythong is correct. When I'm logging in using WinSCP with credentials that applies to that folder from the computer listed in hosts I can normally view/edit files. But when I do it from another computer (not listed on the hosts list) with the same credentials, I can still view/edit data. If I understand correctly, the hosts feature should prevent such action. It is also possible that I don't understand it properly.
EDIT: for clarification about FTP: user have to log (no anonymous allowed), but even when I've changed to anonymous and set a host other than my computer and I logged from my computer, I was still able to view/edit/delete etc.
  • FramerV's avatar
    FramerV
    NETGEAR Employee Retired
    Hi BalROCK,
    I will check if I can replicate this. Do you have some screen shots that I can compare it to?
    • BalROCK's avatar
      BalROCK
      I will be difficult to show entire problem on one screenshot. But I can try, just tell me which behavior you want to see on a screenshot :)
      best regards,
      • FramerV's avatar
        FramerV
        Hi BalROCK,
        We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
        If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
        The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
