avsathish
Aug 24, 2016Follower
How do I backup my datas from local remote system to NAS?
I am trying to backup my local system datas to NAS box but did not. Here are my backup job settings. Source: Type: remote Name: remote: Windows/NAS (Timestamp) Host: <local ip-192.168.1.1> pa...
Aug 24, 2016Guru - Experienced User
192.168.1.1 sounds like your router's IP address, not the PC. Are you certain this is the correct IP address?
Also, if you have a second PC you might want to see if you can access the shared D drive from there (using the same credentials).
If not, you could use a mobile app to test access to the D drive - for example goodreader for IoS, or solid file explorer for Android.
