alokeprasad
Dec 02, 2012Mentor
How do I do a full restore of [c] from attched USB drive?
I have full backup defined as Source: [c] Destination: USB_HDD_3 After factory default, I want to restore the entire [c] volume. When I try to create a backup job to do that, I see the source ...
TeknoJnky
Dec 04, 2012Hero
alokeprasad wrote:
How do I select a specific directory on USB_HDD_1 when restoring back to the share on c:?
For example, I need to select "media" on USB_HDD_1 as source when I select "Share: media" as the destination. I cannot do that currently. I cannot select USB_HDD_1/media as the source.
You would set the "Path" field to "media" without the quotes.
If you need a sub sub folder, you would use linux path:
media/mp3
