pjz28ss
Oct 25, 2015Aspirant
How do I get full 2.0GB Volume size on SPARC Based ReadyNAS Duo?
I recently added a second 2.0GB drive to my ReadyNAS Duo hoping to get to the max spec for the SPARC based Duo. When the sync was complete the volume indicated 1.3GB. I have read that RAID-X has a ...
- Oct 30, 2015
X-RAID should automatically expand.
If you use disk spin-down you should disable that. You should also make sure that the "Disable Journaling" option is not checked.If you need to make changes to those settings. After applying them reboot the NAS again.
mdgm-ntgr
Oct 25, 2015NETGEAR Employee Retired
Have you tried a reboot?
1.3 is what you would expect with 2x1.5TB drives.
