pjz28ss's avatar
pjz28ss
How do I get full 2.0GB Volume size on SPARC Based ReadyNAS Duo?
I recently added a second 2.0GB drive to my ReadyNAS Duo hoping to get to the max spec for the SPARC based Duo.  When the sync was complete the volume indicated 1.3GB.  I have read that RAID-X has a ...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Oct 30, 2015
    X-RAID should automatically expand.
    If you use disk spin-down you should disable that. You should also make sure that the "Disable Journaling" option is not checked.
    If you need to make changes to those settings. After applying them reboot the NAS again.
ProSupport for Business
