oddlimbs
Jun 02, 2009Aspirant
How do I setup recycler/recycle bin on a Readynas Duo?
Hi, I have just inadvertantly deleted a file from one of my shares on my Readynas Duo, I have seen recycler/recycle bin mentioned somewhere, but don't seem to be able to find it! Please can you ...
Sep 26, 2011Guru - Experienced User
When you select "share listing", you should see a list of share names, with icons next to each. The icons are labeled - for instance CIFS NFS FTP/S HTTP/S.
rixter wrote: I am using Raidiator 4.1.8. I don't see a CIFS tab on Frontview > Shares > Share Listing. Just tabs for Share Listing and Add Shares (and nothing about Recycle Bin).
How do I enable the recycle bin?
And where will I find it once enabled?
Assuming CIFS has been enabled as a file protocol (under services), you click on the CIFS icon right next to the share name. At that point you will get a tab view, with one tab for each file protocol + a tab for advanced. The tabs are across the top.
When the CIFS tab is selected, you scroll down a bit and you will see the recycle bin options.
