Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
Sandshark
Apr 12, 2023Sensei
I didn't try initially. But just did, and it does not work. Not sure of the point, anyway, since it's nothing that needs protection from prying eyes.
I forgot to mention in my initial post that you will get some warnings about expired keys, but they are just warnings because you've told the OS to ignore them.
Apr 13, 2023Guru - Experienced User
https would also verify the cert, and provide protection against a man-in-the-middle attack. So there would be some value if it worked (over and above the encryption)
