Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
May 05, 2023Guru - Experienced User
FWIW, you can use apt-mirror for this:
If you set mirrors.list to
deb https://apt.readynas.com/packages/readynasos 6.10.7 updates apps main
deb http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
you can get all three of these repositories.
The Netgear one is about 4 GiB. You can't copy 6.10.8 because Netgear hasn't set the permissions up properly (no one can access it). Hopefully they will fix that soon.
The two Debian 8 repositories total about 72 GiB.
Note I haven't tried to use these yet, I just mirrored them.
- tigertenMay 05, 2023LuminaryI would also recommend adding the retired and archived Debian security repo as well.
Http://archive. Debian.org/Debian-security Jessie/updates main non-free contrib
Something like that. The packages there are newer.- StephenBMay 06, 2023Guru - Experienced User
Http://archive. Debian.org/Debian-security Jessie/updates main non-free contribThx for the tip, I have added that.
One aspect with apt-mirror - it grabs the repository for the platform you are using. So if you are on an x86 machine, it will get the x86 repository.
It will run on the NAS without needing installation, so you can just run it there to make sure you get the repository you need for your platform. Make sure you are saving to the data volume, as the OS partition is far too small.
- tigertenMay 06, 2023Luminary
You can safely delete the pgp files and the inrelease file in the jessie and jessie-backport once local, keeping only the release file. the release file in the jessie-backport has an expiration date in it. You can change that to any date you want. \
You should keep everything in the Jessie-security repo.
This will eliminate all the nagging error messages.
