Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
May 07, 2023Guru - Experienced User
Sandshark wrote:
And I had no problem getting the ARMHF and ARMEL repositories running on an Intel-based system.
Both my RN102 and RN202 downloaded ARMEL with my mirror list (which didn't specify the platform). Not sure what ReadyNAS use ARMHF, but the Netgear repositories include it, so I've also added that.
Here's my current mirror.list
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.0 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.1 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.2 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.3 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.4 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.5 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.6 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.7 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.9 updates apps main
deb-amd64 http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb-amd64 http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
deb-amd64 http://archive.debian.org/debian-security jessie/updates main contrib non-free
deb-armel https://apt.readynas.com/packages/readynasos 6.10.0 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.1 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.2 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.3 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.4 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.5 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.6 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.7 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.9 updates apps main
deb-armel http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb-armel http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
deb-armel http://archive.debian.org/debian-security jessie/updates main contrib non-free
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.0 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.1 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.2 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.3 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.4 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.5 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.6 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.7 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.9 updates apps main
deb-armhf http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb-armhf http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
deb-armhf http://archive.debian.org/debian-security jessie/updates main contrib non-free
Total size is approximately 200 GiB.
eton
May 07, 2023Luminary
I did it like this:
echo 'APT::Get::custom-arguments "--allow-unauthenticated";' >> /etc/apt/apt.conf.d/999myconfigRelated Content
