Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
dhl
Oct 12, 2023Luminary
Sandshark - This is a Pro 6. Will check the ports as you suggest and report back. Thanks!
dhl
Oct 16, 2023Luminary
There was nothing unusual with the port configuration. ETH0 was primary and the only port enabled. I wound up following the instructions from the ZeroTier forum to uninstall/re-install ZeroTier and now everything's back up and running normally. Hopefully it doesn't break again!😉
Thanks for your help!
- cory_boothFeb 01, 2024Initiate
It's been fixed....
ReadyNAS OS 6 Software Version 6.10.10 - NETGEAR Support
/s- StephenBFeb 01, 2024Guru - Experienced User
cory_booth wrote:
It's been fixed....
ReadyNAS OS 6 Software Version 6.10.10 - NETGEAR SupportNo, 6.10.10 totally removed the GUI install, and also changed the apt configuration so it doesn't work at all.
- XtheUnknownFeb 01, 2024Apprentice
It's worse than that, Jim...
I have a VM which (as a test) I upgraded from 6.10.8 to 6.10.10. Not only did it remove the ability to upload apps by file browser and the "available apps" tab, it also removed existing installed apps, including SMBPLUS. I didn't have Plex installed on the VM, but I assume it would do that too - and lose all my Plex configuration data...
This is a dangerous update, which could lead to loss of user (configuration) data, and I will be staying well clear on my production and backup devices (unless @sandshark or StephenB advise otherwise).
