Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
Dankel2
Mar 29, 2024Aspirant
For Plex app (probably any other app also) if anyone has a ReadyNAS 312 like I do you may want to try and downgrade from 6.10.10 to 6.10.9, reboot and then install/update Plex app from the GUI. This is what I did and I'm working again. All my Available Apps and Installed Apps are back. Worth a try.....
Sandshark
Mar 30, 2024Sensei
Just downgrading the OS is sufficient for a Plex update because it needs no new dependencies from the Debian archive. Updates to others likely will be the same, since Debian 8 hasn't been updated in some time. But for most new installations, it's going to need access to the Debian archive to download dependencies, so the changes listed here are required.
