Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
Sandshark
May 07, 2023Sensei
I did successfully use apt-mirror to create local repositories. And I had no problem getting the ARMHF and ARMEL repositories running on an Intel-based system. But I did have to run it on a Linux platform other than the NAS itself.
Mar 25, 2025Guru - Experienced User
FYI, the keys in the debian archives are beginning to expire. You need to add this to apt.conf to overcome that problem:
Acquire::Check-Valid-Until false;- vandermerweApr 26, 2025Master
Thanks for the advice posted here:
I've done the update, which introduced one additional error which I've highlighted below.
root@mainnas:~# apt-get update
Hit:1 http://archive.debian.org/debian-security jessie/updates InRelease
Ign:2 http://archive.kernel.org/debian-archive/debian jessie InRelease
Get:3 http://archive.kernel.org/debian-archive/debian jessie-backports InRelease [166 kB]
Ign:4 https://apt.readynas.com/packages/readynasos 6.10.9 InRelease
Ign:5 https://apt.readynas.com/packages/readynasos 6.10.9 Release
Get:6 http://archive.kernel.org/debian-archive/debian jessie Release [148 kB]
Ign:3 http://archive.kernel.org/debian-archive/debian jessie-backports InRelease
Ign:7 https://apt.readynas.com/packages/readynasos 6.10.9/updates amd64 Packages.diff/Index
Ign:8 https://apt.readynas.com/packages/readynasos 6.10.9/updates all Packages
Get:9 http://archive.kernel.org/debian-archive/debian jessie Release.gpg [2,420 B]
Ign:9 http://archive.kernel.org/debian-archive/debian jessie Release.gpg
Ign:10 https://apt.readynas.com/packages/readynasos 6.10.9/apps amd64 Packages.diff/Index
Get:11 http://archive.kernel.org/debian-archive/debian jessie/main amd64 Packages [6,818 kB]
Ign:12 https://apt.readynas.com/packages/readynasos 6.10.9/apps all Packages
Ign:13 https://apt.readynas.com/packages/readynasos 6.10.9/main amd64 Packages.diff/Index
Ign:14 https://apt.readynas.com/packages/readynasos 6.10.9/main all Packages
Ign:15 https://apt.readynas.com/packages/readynasos 6.10.9/updates amd64 Packages
Ign:16 https://apt.readynas.com/packages/readynasos 6.10.9/apps amd64 Packages
Ign:17 https://apt.readynas.com/packages/readynasos 6.10.9/main amd64 Packages
Err:15 https://apt.readynas.com/packages/readynasos 6.10.9/updates amd64 Packages
403 Forbidden
Get:18 http://archive.kernel.org/debian-archive/debian jessie/contrib amd64 Packages [49.8 kB]
Get:19 http://archive.kernel.org/debian-archive/debian jessie/non-free amd64 Packages [83.2 kB]
Fetched 7,267 kB in 16s (438 kB/s)
Reading package lists... Done
W: The repository 'https://apt.readynas.com/packages/readynasos 6.10.9 Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: http://archive.kernel.org/debian-archive/debian jessie-backports InRelease: The following signatures were invalid: KEYEXPIRED 1587841717 KEYEXPIRED 1668891673
W: GPG error: http://archive.kernel.org/debian-archive/debian jessie Release: The following signatures were invalid: KEYEXPIRED 1587841717
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.9/updates/binary-amd64/Packages 403 Forbidden
E: Some index files failed to download. They have been ignored, or old ones used instead.I am trying to install a plugin for Lyrion music server (which installed successfully after the update), but I am getting an fatal error saying Kernel too old with one of the binaries used for the addon.
If I use the other binary I get other errors:
/var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64: /usr/lib/x86 _64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /var/lib/squeezeboxserver/cache/I nstalledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64)
/var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64: /usr/lib/x86 _64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /var/lib/squeezeboxserver/cache/Ins talledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64)If I apt-get install libstdc++6 it is there and a much newer version.
So I seem to be stuck between the proverbial rock and a hard place.
Any advice welcome, I have of course presented this problem to the owner of the addon as well.
403 Forbidden
Any advice welcome, I have of course presented this problem to the owner of the addon as well.- SandsharkApr 27, 2025Sensei
Nothing in this post is going to help you update the kernel. Even if you re-build the kernel, I doubt you can include what that package is looking for and maintain compatibility with the rest of the OS.
There are many packages you cannot update past a specific point because of Linux Jessie. I can't say if that package is one of them.
- vandermerweApr 27, 2025MasterI was expecting that to be the case. I wasn’t expecting to be able to update the kernel but the other error regarding components of C++ suggested that the version I had was newer than the version sought by the addon?
When I did the apt-get update I had an additional error not mentioned in your posts:
Is this a problem?
- lancerus77May 02, 2025Aspirant
LMS - once you start going down the road of an app which needs a newer libc, or newer libc++, or a newer kernel - its a lost cause. Those parts of the system are fixed - things around them ... can be changed/modified, etc.
LMS does run within docker. Depending on which readynas you have (like a 5xx, or 6xx series) - going down the docker path could be a path to getting that app running directly on the nas. But is worth it - or would working with a NUC (nice and cheap, run any OS you want) - be the quicker and easier path.
Just some thoughts there ...
