Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
vandermerwe
Apr 26, 2025Master
Thanks for the advice posted here:
I've done the update, which introduced one additional error which I've highlighted below.
root@mainnas:~# apt-get update
Hit:1 http://archive.debian.org/debian-security jessie/updates InRelease
Ign:2 http://archive.kernel.org/debian-archive/debian jessie InRelease
Get:3 http://archive.kernel.org/debian-archive/debian jessie-backports InRelease [166 kB]
Ign:4 https://apt.readynas.com/packages/readynasos 6.10.9 InRelease
Ign:5 https://apt.readynas.com/packages/readynasos 6.10.9 Release
Get:6 http://archive.kernel.org/debian-archive/debian jessie Release [148 kB]
Ign:3 http://archive.kernel.org/debian-archive/debian jessie-backports InRelease
Ign:7 https://apt.readynas.com/packages/readynasos 6.10.9/updates amd64 Packages.diff/Index
Ign:8 https://apt.readynas.com/packages/readynasos 6.10.9/updates all Packages
Get:9 http://archive.kernel.org/debian-archive/debian jessie Release.gpg [2,420 B]
Ign:9 http://archive.kernel.org/debian-archive/debian jessie Release.gpg
Ign:10 https://apt.readynas.com/packages/readynasos 6.10.9/apps amd64 Packages.diff/Index
Get:11 http://archive.kernel.org/debian-archive/debian jessie/main amd64 Packages [6,818 kB]
Ign:12 https://apt.readynas.com/packages/readynasos 6.10.9/apps all Packages
Ign:13 https://apt.readynas.com/packages/readynasos 6.10.9/main amd64 Packages.diff/Index
Ign:14 https://apt.readynas.com/packages/readynasos 6.10.9/main all Packages
Ign:15 https://apt.readynas.com/packages/readynasos 6.10.9/updates amd64 Packages
Ign:16 https://apt.readynas.com/packages/readynasos 6.10.9/apps amd64 Packages
Ign:17 https://apt.readynas.com/packages/readynasos 6.10.9/main amd64 Packages
Err:15 https://apt.readynas.com/packages/readynasos 6.10.9/updates amd64 Packages
403 Forbidden
Get:18 http://archive.kernel.org/debian-archive/debian jessie/contrib amd64 Packages [49.8 kB]
Get:19 http://archive.kernel.org/debian-archive/debian jessie/non-free amd64 Packages [83.2 kB]
Fetched 7,267 kB in 16s (438 kB/s)
Reading package lists... Done
W: The repository 'https://apt.readynas.com/packages/readynasos 6.10.9 Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: http://archive.kernel.org/debian-archive/debian jessie-backports InRelease: The following signatures were invalid: KEYEXPIRED 1587841717 KEYEXPIRED 1668891673
W: GPG error: http://archive.kernel.org/debian-archive/debian jessie Release: The following signatures were invalid: KEYEXPIRED 1587841717
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.9/updates/binary-amd64/Packages 403 Forbidden
E: Some index files failed to download. They have been ignored, or old ones used instead.
I am trying to install a plugin for Lyrion music server (which installed successfully after the update), but I am getting an fatal error saying Kernel too old with one of the binaries used for the addon.
If I use the other binary I get other errors:
/var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64: /usr/lib/x86 _64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /var/lib/squeezeboxserver/cache/I nstalledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64)
/var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64: /usr/lib/x86 _64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /var/lib/squeezeboxserver/cache/Ins talledPlugins/Plugins/RaopBridge/Bin/squeeze2raop-linux-x86_64)
If I apt-get install libstdc++6 it is there and a much newer version.
So I seem to be stuck between the proverbial rock and a hard place.
Any advice welcome, I have of course presented this problem to the owner of the addon as well.
Sandshark
Apr 27, 2025Sensei
Nothing in this post is going to help you update the kernel. Even if you re-build the kernel, I doubt you can include what that package is looking for and maintain compatibility with the rest of the OS.
There are many packages you cannot update past a specific point because of Linux Jessie. I can't say if that package is one of them.
- vandermerweApr 27, 2025MasterI was expecting that to be the case. I wasn’t expecting to be able to update the kernel but the other error regarding components of C++ suggested that the version I had was newer than the version sought by the addon?
When I did the apt-get update I had an additional error not mentioned in your posts:
Is this a problem? - SandsharkApr 28, 2025Sensei
That sounds like Netgear took down the server. Probably not a problem since everything in it is likely already installed in the NAS. But it would make it impossible to re-build the kernel.
