Sandshark
Apr 11, 2023Sensei
How I got apt update and install to work (with Debian Jessie retired)
OK, so I started off creating my own local Debian repository. Not recommended -- it's a lot of work. But with a lot of Googling and experimenting, I finally got apt to work using an online source. ...
May 07, 2023Guru - Experienced User
Sandshark wrote:
And I had no problem getting the ARMHF and ARMEL repositories running on an Intel-based system.
Both my RN102 and RN202 downloaded ARMEL with my mirror list (which didn't specify the platform). Not sure what ReadyNAS use ARMHF, but the Netgear repositories include it, so I've also added that.
Here's my current mirror.list
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.0 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.1 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.2 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.3 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.4 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.5 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.6 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.7 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
deb-amd64 https://apt.readynas.com/packages/readynasos 6.10.9 updates apps main
deb-amd64 http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb-amd64 http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
deb-amd64 http://archive.debian.org/debian-security jessie/updates main contrib non-free
deb-armel https://apt.readynas.com/packages/readynasos 6.10.0 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.1 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.2 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.3 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.4 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.5 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.6 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.7 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
deb-armel https://apt.readynas.com/packages/readynasos 6.10.9 updates apps main
deb-armel http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb-armel http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
deb-armel http://archive.debian.org/debian-security jessie/updates main contrib non-free
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.0 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.1 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.2 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.3 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.4 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.5 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.6 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.7 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
deb-armhf https://apt.readynas.com/packages/readynasos 6.10.9 updates apps main
deb-armhf http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb-armhf http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
deb-armhf http://archive.debian.org/debian-security jessie/updates main contrib non-free
Total size is approximately 200 GiB.
lancerus77
May 02, 2025Aspirant
Reaching for the moon with this question .... so StevenB had the following 200gb mirrored 2 years ago. Is there any possibility that could be shared - mirrored to others - and/or does anyone else have the packages repos mirrored that could be cloned ?
I've already mirrored jessie and have a local webserver feeding it. I'm just missing a clean setup for the readynas packages world.
I'm a tad late to the game here - but I have many systems and would rather self-support (and modify) them in a clean way instead of hacking thru it.
Cheers -
Edit: Hmm. I thought StevenB's post would have been linked to my reply. Anyway - its back on the first page of this same topic - posted back on 2023-05-07 - his long list of mirrored repos.
- scozzaroMay 02, 2025Aspirant
- update soruces.list:
echo "deb [trusted=yes] http://archive.kernel.org/debian-archive/debian/ jessie main" >> /etc/apt/sources.list
- apt-get update
- apt-key list | grep expired -A1
- apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 46925553
- apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 1587841717
- apt-key adv --recv-keys --keyserver hkp://keyserver.ubuntu.com 7638D0442B90D010
- apt-get install nano
- update sources.list cd /etc/apt
deb https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
# deb http://mirrors.kernel.org/debian jessie main
# deb http://security.debian.org/ jessie/updates main
deb [trusted=yes] http://archive.kernel.org/debian-archive/debian jessie main contrib non-free
deb [trusted=yes] http://archive.kernel.org/debian-archive/debian jessie-backports main contrib non-free
- lancerus77May 02, 2025Aspirant
Nothing under apt.readynas.com exists anymore (unless I'm missing something in my searches).
This doesnt exist for example:
