grish4
Apr 15, 2017Aspirant
how long does it take to OS reinstall ?
hello, I began an OS reinstal 7 hours ago and the NAS still showing a "booting... updating FW" message. What's the next step ? thank's for your help. grish4
- Apr 22, 2017
Updated the firmware to 6.7.1 Beta 2 and was able to mount the data volume with the option to disable volume quotas fine.
Rebooted it to normal mode and it came up fine.
Oh and for good measure I updated the BIOS to the latest.
Apr 15, 2017Guru - Experienced User
An OS reinstall should take a couple of minutes at most.
Do you have a backup of your data?
- Jul 15, 2018Anonymous
