grish4
Apr 15, 2017Aspirant
how long does it take to OS reinstall ?
hello, I began an OS reinstal 7 hours ago and the NAS still showing a "booting... updating FW" message. What's the next step ? thank's for your help. grish4
- Apr 22, 2017
Updated the firmware to 6.7.1 Beta 2 and was able to mount the data volume with the option to disable volume quotas fine.
Rebooted it to normal mode and it came up fine.
Oh and for good measure I updated the BIOS to the latest.
jak0lantash
Apr 15, 2017Mentor
Can you explain why did you start an OS Reinstall? That's most likely important information to understand what's happening.
- grish4Apr 16, 2017Aspirant
Hi,
booting stop on 31%.
That's why I tried to reinstal the OS.
Can it be useful to tempt this two or three times ? there's nothing on it that I can't loss, but I wan't try all procedure existing before the factory reboot.
Is USB key restart the next candidate ? does that erase data ?
is it useful to try a boot with no disk ?
thanks
- jak0lantashApr 16, 2017Mentor
USB Boot Recovery is to rewrite the flash, I doubt it would help in this case.
Booting without disk is pointless as the system and settings are on the disks.
31% seems early stage though. Anything happened before this condition?
Maybe you should contact NETGEAR Support... Especially if you don't want to take any risk with your data.
ok.
I have saved the configuration but the system must be up to be restored.
with a lot of OS you can boot on an external device and access repair tools, i'm surprised it is not the same with the readynas OS.
I try a disk test. Disk are in raid 6 in flex mode.
does the disk test have a repair function ?
How is it possble to have 6 disk, six replication possibily of the OS and not one in goof shape ?
i snapshot the system, is there a way to come back to the previous image ?
I use two things : the amazon sync and the DLNA. I've only one gig of ram can this cause unstability ?
One thing : when cold, the start time between the push on the button and the moment when the fan begin to run at full speed is almost 5 min. If I do a reboot it's take no time at all.
- Jul 15, 2018Anonymous
