Deal
Nov 15, 2015Tutor
How to access SSH after EnableSSH is installed?
I have a ReadyNAS Pro Business edition running RAIDiator 4.2.27. I had subsonic 4.7 running (from super-poussin) on it and upgraded to 5.1. I've noticed two problems after that that I'm trying to res...
- Nov 16, 2015
I would use the putty.exe file from here: http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
I think you should be O.K. with those, but still best to make sure your backup is up to date before you do this.
mdgm-ntgr
Nov 16, 2015NETGEAR Employee Retired
Deal
Nov 16, 2015Tutor
Thanks for the tip. Worked wonderfully. Now I can see that ffmpeg is already in the directory where I wanted to ccreate a symbolic link (so that failed). But I can access SSH now. Thank you.
David
- DealNov 17, 2015TutorNow my problem is that ffmpeg is somehow not transcoding flac files when Subsonic sends a file to ffmpeg. The log of what happens when I attempt to play a flac file is above. I have no idea what's broken. Any help would be appreciated. Running Subsonic 5.1 on a ReadyNAS Pro with about 18TB free of 24TB total, and stock RAM. Note that MP3 file play with no issue (they don't need transcoding). TIA David
I forgot to post the message with the log in it. It is below.
I thought my problem was that ffmpeg was missing from the transcode subdirectory, so I followed the advice above only to find out that ffmpeg is already in the transcode subdirectory. Btw, the full path to it is /webroot/subsonic/transcode - that's different from what I've read on these forum pages in some places. Anyway, the problem.
My problem is when I attempt to play a flac file on my iPad, which needs transcoding, if the file isn't already in the cache, I get a popup error message sayting "Uh oh! We asked for a song, but the server didn't send anything! It's likely that Subsonic's transcoding failed." This error message is what lead me down the path of checking out ffmpeg. But it appears to be present in the right location. And I have not changed any of the configuration parameters on the settings tab within Subsonic. So I'm out of ideas wrt what's wrong. Below is a copy of the subsonic about box when a song fails transcoding. Any help figuring this out would be appreciated.
[11/15/15 9:15:42 PM EST] DEBUG TranscodeInputStream Starting transcoder: [/c/webroot/subsonic/transcode/ffmpeg] [-i] [/c/media/Music/Anita Baker/Compositions/04 - Soul Inspiration.flac] [-map] [0:0] [-b:a] [320k] [-v] [0] [-f] [mp3] [-]
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) ffmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) built on May 10 2011 08:03:44 with gcc 4.3.2
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) configuration: --enable-pthreads --disable-shared --enable-static --enable-gpl --enable-libx264 --enable-libmp3lame
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) libavutil 51. 2. 1 / 51. 2. 1
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) libavcodec 53. 3. 0 / 53. 3. 0
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) libavformat 53. 0. 3 / 53. 0. 3
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) libavdevice 53. 0. 0 / 53. 0. 0
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) libavfilter 2. 4. 0 / 2. 4. 0
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) libswscale 0. 14. 0 / 0. 14. 0
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) [flac @ 0x8d9fc60] max_analyze_duration reached
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) Input #0, flac, from '/c/media/Music/Anita Baker/Compositions/04 - Soul Inspiration.flac':
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) Metadata:
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) REPLAYGAIN_ALBUM_GAIN: -6.23 dB
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) REPLAYGAIN_ALBUM_PEAK: 1
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) ACCURATERIPDISCID: 009-00105486-007870ff-690bdc09-4
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) ACCURATERIPRESULT: AccurateRip: Accurate (confidence 28) [29629FAB]
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) album_artist : Anita Baker
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) RATING : 3
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) TITLE : Soul Inspiration
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) UPC : 07559609221
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) COMPOSER : Terry Britten;Graham Lyle
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) REPLAYGAIN_TRACK_GAIN: -7.1 dB
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) REPLAYGAIN_TRACK_PEAK: 0.997498
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) track : 4
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) ALBUM : Compositions
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) ARTIST : Anita Baker
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) GENRE : Jazz;R&B;Vocal
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) DATE : 1990
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) BAND : Anita Baker
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) TOTALTRACKS : 9
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) disc : 1
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) TOTALDISCS : 1
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) ENCODEDBY : dbPoweramp Reference 13.1
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) STYLE : Quiet Storm;Adult Contemporary;Urban;Soul
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) BANDSORTORDER : Baker, Anita
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) COMPOSERSORTORDER: Britten, Terry;Lyle, Graham
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) TOOL NAME : Media Center
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) TOOL VERSION : 13.0.132
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) JR_DATE : 32874
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) PEAK LEVEL : 0.9975000023841858
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) BPM : 103
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) REPLAY GAIN : -13.0410499572753906
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) INTENSITY : 2
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) Duration: 00:05:19.40, bitrate: 974 kb/s
[11/15/15 9:15:42 PM EST] DEBUG InputStreamReaderThread (/c/webroot/subsonic/transcode/ffmpeg) Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[11/15/15 9:16:32 PM EST] INFO PlayerDao Created player 8.
