sylvainp
Sep 07, 2024Aspirant
How to add UPS using snmp to shutdown NAS
Hi all, I recently got a good deal on a refurbished APC SMT1500 and I also bought the Network card (AP9631) sor vey cheap, My mainly use here is to only use an ethernet cable on the UPS and to shutdo...
Sandshark
Sep 08, 2024Sensei
It would be helpful to know the OS version you are running.
I use a Eaton 1500P with network card and it works fine with 6.10.9, so I can say that basic SMTP monitoring and shut-down of an UPS does work. But since mine is a different brand, I can't say if there is a problem with the APC specifically.
sylvainp
Sep 08, 2024Aspirant
OS is version 6.10.10 on the NAS, For the APC side I have update all firmware on the UPS and the NMC card.
Maybe I need to go on battery and see if it will shutdown properly. I only tried the Control shutdown of the outlet with a wait time to shutdown. The PC shutdown gracefully but the NAS did nothing.
- SandsharkSep 08, 2024Sensei
A good way to test that is to connect the NAS to a wall outlet instead of the UPS and have another load on the UPS. Then unplug the UPS and see if the NAS shuts down at the appropriate time. That way, should it not shut down, you don't have an improper power interruption to the NAS.
