McRob1
Feb 19, 2017Luminary
How to backup from remote to local
I am looking for help on the best method to do scheduled weekly backups from a local NAS to a remote NAS. Both NAS's are running OS 6.6.1 Local NAS is ReadyNAS Pro 6 Remote NAS is ReadyNAS 516 ...
Feb 20, 2017Guru - Experienced User
Note that the above method does not use ReadyCloud - it assumes that both ReadyNAS are on the same network.
Just to amplify this - a method you could use is here: http://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-with-rsync-over-SSH?cid=wmt_netgear_organic
I think you can also set up ZeroTier on both NAS and back up using the ZeroTier IP addresses - perhaps Sandshark can chime in on that.
