AndreasKa
Jan 31, 2015Tutor
How to cCheck Size of a share/folder?
I may be missing something very simple here but I can't seem to view the size of a share or any folder via the web admin -> shares menu. When using the list view, there are 4 columns;Name, Type, Size...
Hephaestus1
May 19, 2015Aspirant
For solution see: viewtopic.php?f=7&t=81129
bizmate
Jul 22, 2022Tutor
it looks like this link is dead? is there something that can be enabled to see the folder sizes, if copied to an outside disk that is?
- StephenBJul 22, 2022Guru - Experienced User
You can see the,on-disk space by enabling quota on the volume settings page, and then looking at the shares page in the admin web ui.
That space includes the space consumed by snapshots.
