AndreasKa
Jan 31, 2015Tutor
How to cCheck Size of a share/folder?
I may be missing something very simple here but I can't seem to view the size of a share or any folder via the web admin -> shares menu. When using the list view, there are 4 columns;Name, Type, Size...
May 12, 2015Guru - Experienced User
It's simple for the entire volume because the file system does know how many data blocks are used in total. Without the quota feature I mentioned above, btrfs doesn't have an easy way to track how many data blocks are uniquely used in each folder when snapshots are enabled.
Hephaestus wrote: I am not certain why it was possible to do it for full volume, yet it is supposedly so difficult to have similar indicators next to each share/folder. This is pretty basic functionality - and is still sadly missing.
Some of the other proposed features (in particular using --reflink by default when moving files between shares) make this problem more complicated, since it extends CoW across share boundaries. That is, moving a file that way will result in the data blocks being shared between the new share, the new share's snapshots and the old share's snapshots.
I also want the feature (along with some better tools to manage snapshots generally). But there are cases where such indicators will be confusing - for instance when CoW is extended across shares, the sum of the space used in each share won't add up to the total space used in the volume.
