AndreasKa
Jan 31, 2015Tutor
How to cCheck Size of a share/folder?
I may be missing something very simple here but I can't seem to view the size of a share or any folder via the web admin -> shares menu. When using the list view, there are 4 columns;Name, Type, Size...
Hephaestus1
May 15, 2015Aspirant
Hypothetically, if a file system consisted of one file only, the file being 1GB, this file consumes 1GB of physical disk space.
If a file system consists of more files (usually the case), the same file does not consume 1GB of physical disk space (shared blocks).
Thus "size of a single file" really means: the size when the file is copied outside of ReadyNAS OS environment. Adding all files sizes within a folder, and showing the result as folder/share size would simply follow already adopted logic: this is the size of the folder when it is copied outside of ReadyNAS OS environment. Showing size of files and not showing the size of folders is logically inconsistent.
