AndreasKa
Jan 31, 2015Tutor
How to cCheck Size of a share/folder?
I may be missing something very simple here but I can't seem to view the size of a share or any folder via the web admin -> shares menu. When using the list view, there are 4 columns;Name, Type, Size...
May 15, 2015Guru - Experienced User
Thought experiment (a): Let's say you have a share with a single 1 GB MP4 file in it. You take 1 snapshot.
Hephaestus wrote: Hypothetically, if a file system consisted of one file only, the file being 1GB, this file consumes 1GB of physical disk space.
If a file system consists of more files (usually the case), the same file does not consume 1GB of physical disk space (shared blocks).
Thus "size of a single file" really means: the size when the file is copied outside of ReadyNAS OS environment. Adding all files sizes within a folder, and showing the result as folder/share size would simply follow already adopted logic: this is the size of the folder when it is copied outside of ReadyNAS OS environment. Showing size of files and not showing the size of folders is logically inconsistent.
The folder+snapshot will be reported as 2 GB total space by btrfs, but the actual disk space used is only 1 GB.
Now let's change the thought experiment.
Thought experiment (b): Now you add a tag to that MP4 file which rewrites all the data in the file (shifting it a little bit). BTRFS will again report the folder+snapshot as taking 2 GB. And now it will actually take 2 GB of space.
So btrfs (without the quota option enabled) can't tell you how much actual disk space is used by the folder and its associated snapshots.
Now there is some use for simply knowing the total file space in the main share - ignoring the snapshots and CoW and simply summing up the sizes of the files as you say. That number is readily available in ssh (the normal du command will give it to you). And it could be easily added to the GUI.
But I am interested in knowing the actual disk space used by the folder+snapshots too - because I can use that to tell me where I need to delete snapshots as the disk fills.
