AndreasKa
Jan 31, 2015Tutor
How to cCheck Size of a share/folder?
I may be missing something very simple here but I can't seem to view the size of a share or any folder via the web admin -> shares menu. When using the list view, there are 4 columns;Name, Type, Size...
Hephaestus1
May 19, 2015Aspirant
For solution see: viewtopic.php?f=7&t=81129
- bizmateJul 22, 2022Tutor
it looks like this link is dead? is there something that can be enabled to see the folder sizes, if copied to an outside disk that is?
- StephenBJul 22, 2022Guru - Experienced User
You can see the,on-disk space by enabling quota on the volume settings page, and then looking at the shares page in the admin web ui.
That space includes the space consumed by snapshots.
