gyves1's avatar
gyves1
Luminary
Mar 16, 2017
How to clean up the system volume "root" without factory reset to improve the ReadyNas performances?
One of moderators said me that my "root" is too full.
How can I clean up the system volume "root" without factory reset to improve the ReadyNas performances ?
Is there an application or add-on on Netgear ReadyNas market place to download and could help to clean up the system like the CCcleaner app from Piriform?
Thanks in advance,
Best regards,
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You'd need to SSH in as the 'root' (no quotes) user and have a log around e.g.
    # mount --bind / /mnt
    # du -csh /mnt/*
    • gyves1's avatar
      gyves1
      Luminary
      Here the log:
      =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.03.16 23:02:19 =~=~=~=~=~=~=~=~=~=~=~=
      login as: root
      root@homedisk's password:
      Welcome to ReadyNASOS 6.6.1
      Last login: Thu Mar 16 22:35:28 2017 from fe80::dde2:6310:93e8:f9f0%bond0
      root@homedisk:~# mount --bind / /mnt
      root@homedisk:~# du -csh /mnt/*
      0/mnt/apps
      7.4M/mnt/bin
      0/mnt/boot
      0/mnt/config
      8.0K/mnt/cp_check_md5sums.sh
      0/mnt/data
      24K/mnt/dev
      0/mnt/Downloads
      13M/mnt/etc
      0/mnt/evs_temp
      29M/mnt/frontview
      0/mnt/home
      0/mnt/Incomplete
      34M/mnt/lib
      3.6M/mnt/lib32
      4.0K/mnt/lib64
      28K/mnt/media
      0/mnt/mnt
      5.8M/mnt/opt
      0/mnt/proc
      0/mnt/+ÌR
      32K/mnt/root
      0/mnt/run
      11M/mnt/sbin
      0/mnt/selinux
      0/mnt/srv
      0/mnt/sys
      18M/mnt/tempdata
      4.0K/mnt/test_crontab.txt
      4.0K/mnt/tmp
      702M/mnt/usr
      359M/mnt/var
      1.2Gtotal
    You'll have to do things manually from SSH.
    Please send the output of the following commands:
    mount --bind / /mnt
    du -d1 -h /mnt/
    • gyves1's avatar
      gyves1
      Luminary
      Here the second result
      =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.03.16 23:13:16 =~=~=~=~=~=~=~=~=~=~=~=
      login as: root
      root@homedisk:~# du -d1 -h /mnt/
      7.4M/mnt/bin
      0/mnt/boot
      24K/mnt/dev
      13M/mnt/etc
      0/mnt/home
      34M/mnt/lib
      4.0K/mnt/lib64
      28K/mnt/media
      0/mnt/mnt
      5.8M/mnt/opt
      0/mnt/proc
      32K/mnt/root
      0/mnt/run
      11M/mnt/sbin
      0/mnt/selinux
      0/mnt/srv
      0/mnt/sys
      4.0K/mnt/tmp
      702M/mnt/usr
      357M/mnt/var
      0/mnt/data
      0/mnt/apps
      18M/mnt/tempdata
      112K/mnt/.conf
      0/mnt/.work
      16K/mnt/.log
      0/mnt/.events
      3.6M/mnt/lib32
      0/mnt/config
      0/mnt/Downloads
      0/mnt/Incomplete
      24M/mnt/.dropbox
      0/mnt/evs_temp
      29M/mnt/frontview
      1.2G/mnt/
      root@homedisk:~#
  • I have installed the add-on log analyser to know if I can see something wrong or bad...
    I see some a lot of errors:
    • ERROR: Can't change dir to /var/lib/clamav
    • Failed to start ClamAV virus database updater.
    • (*system*php5) WRONG FILE OWNER (/etc/cron.d/php5)
    • clamav-freshclam.service: Failed with result 'exit-cod
    • fvamazon __acd_io_generic_readwrite: acd io read write error (1) after retrying 0 times!
  • 1.2GB used on a 4GB volume is not a concerning situation. You certainly have some apps installed which makes the used space a little bigger, but there is nothing more to it ;)
ProSupport for Business
