makkistyle
Mar 17, 2024Tutor
how to downgrade my NAS firmware from 6.10.10
Hi, I'm not a developer geek and don't know how to use the codes or ssh is there easy way to downgrade the OS .. I searched and found option in admin page to do so .. but it requires me to u...
- Mar 22, 2024
Indeed, sources.list.d seems to be a place where apps can put their own sources.list and not worry that an OS update will change them. On my VM with Docker installed, it's sources list is there, called docker-cli-rnapp.list. Don't do anything with them. You need to put apt.conf and the updated sources.list in /etc/apt.
Mar 17, 2024Guru - Experienced User
in admin page to do so .. but it requires me to upload the file for it and I don't have the old OS ..
You can get it from here:
Best to extract it from the zip file before you upload.
the issue is that I can't update my Plex app anymore ...
Unfortunately, download back to 6.10.9 likely won't be enough. I believe you will find that you will need to update the two files in this thread:
You can download them from post 37 in the thread.
If you enable SSH on the NAS, you can then install them using WinSCP on the PC. If you set the protocol to SFTP, you should get access to the /etc folder from that GUI. This approach doesn't require knowledge of SSH commands.
makkistyle
Mar 21, 2024Tutor
Hi,
Thanks for your quick reply .. I manage to downgrade the OS only
the next step I was not able to connect to the server as SFTP
and wasn't able to use admin control panel ..
what the correct address to connect via SFTP app :
I use Mac app :
and in CP I activate the FTP but there was not option for SFTP:
what do you mean by GUI ?
