makkistyle
Mar 17, 2024Tutor
how to downgrade my NAS firmware from 6.10.10
Hi, I'm not a developer geek and don't know how to use the codes or ssh is there easy way to downgrade the OS .. I searched and found option in admin page to do so .. but it requires me to u...
- Mar 22, 2024
Indeed, sources.list.d seems to be a place where apps can put their own sources.list and not worry that an OS update will change them. On my VM with Docker installed, it's sources list is there, called docker-cli-rnapp.list. Don't do anything with them. You need to put apt.conf and the updated sources.list in /etc/apt.
Mar 21, 2024Guru - Experienced User
You need to enable ssh in the NAS in order to get sftp to work. Make sure you enable password authentication when you do that.
Also, log in as "root", not as "admin". But still use the NAS admin password.
makkistyle
Mar 21, 2024Tutor
I loged in
but the root is empty
am i missing something ?
- StephenBMar 21, 2024Guru - Experienced User
I'm not a Mac user, but I am confused what the settings for "Root URL", "Local Path" and "Remote Path" are about.
The normal path for the NAS would be /
- makkistyleMar 21, 2024Tutor
I manage to access :
can you just guide me for last step
I just have to replace the file I downloaded ( sources.list ) over NAS version ?
what about the file ( apt.conf ) where it should go ?
there is a file ( apt.conf.d )
and this what shows inside :
