makkistyle
Mar 17, 2024Tutor
how to downgrade my NAS firmware from 6.10.10
Hi, I'm not a developer geek and don't know how to use the codes or ssh is there easy way to downgrade the OS .. I searched and found option in admin page to do so .. but it requires me to u...
- Mar 22, 2024
Indeed, sources.list.d seems to be a place where apps can put their own sources.list and not worry that an OS update will change them. On my VM with Docker installed, it's sources list is there, called docker-cli-rnapp.list. Don't do anything with them. You need to put apt.conf and the updated sources.list in /etc/apt.
makkistyle
Mar 21, 2024Tutor
I loged in
but the root is empty
am i missing something ?
Mar 21, 2024Guru - Experienced User
I'm not a Mac user, but I am confused what the settings for "Root URL", "Local Path" and "Remote Path" are about.
The normal path for the NAS would be /
