makkistyle
Mar 17, 2024Tutor
how to downgrade my NAS firmware from 6.10.10
Hi, I'm not a developer geek and don't know how to use the codes or ssh is there easy way to downgrade the OS .. I searched and found option in admin page to do so .. but it requires me to u...
- Mar 22, 2024
Indeed, sources.list.d seems to be a place where apps can put their own sources.list and not worry that an OS update will change them. On my VM with Docker installed, it's sources list is there, called docker-cli-rnapp.list. Don't do anything with them. You need to put apt.conf and the updated sources.list in /etc/apt.
adinx
Oct 13, 2024Aspirant
Hello friends,
Thanks for finding a solution to the problem.
Unfortunately for me, i have followed the instructions but still get an error message - "apps operation failed" when I try to update my Plex.
I downgraded to 6.10.9, renamed the apt.conf.d to apt.conf.d.orig, renamed the sources.list that is already in the folder to sources.list.orig, added the mods to the /etc/apt folder and tried updating my Plex.
Please is there any step I am missing?
Sandshark StephenB any help will truly be appreciated.
Oct 14, 2024Guru - Experienced User
Maybe try installing the deb file from ssh? That would give a more informative error.
You could also look in apt-install.log and apt-history.log in the log zip file, the error details should also be in there.
