MSR1
Feb 21, 2012Follower
How to enable a trash folder on ReadyNAS Duo 2
I want to be able to set up a Trash bin on the ReadyNAS Duo that functions similarly to the Windows Recycle Bin (deleted items go into the bin until the trash is emptied). Although I've read posts on...
taylord01
Mar 24, 2012Guide
Hi there. Question along same thread.
I have the ReadyNas Duo, running Radiator 4.1.8.
I have enabled RECYCLE BIN under each of my SHARES (Backup, Downloads, Media). I have set 'Remove files older than : 20days' and 'Limit Recycle Bin to: 2000MB'
However, when I delete a file from within one of the Shares, I get a dialogue box telling me 'This item will be deleted immediately. You can’t undo this action. Cancel / Delete'. I hit DELETE. The file is deleted but does not appear in the relevant RECYCLE BIN folder.
Any ideas??
Many thanks
Any ideas??
Many thanks
